head gaskets and studs
Old Jan 8, 2010 | 09:46 AM
M/T_Performance's Avatar
Default head gaskets and studs
i recently blew my head gaskets and was wondering what are the best ones to buy so this doesnt happen again
and does anybody know where i can get some cheap and some head studs? every set i have seen is expensive
thanks alot
Old Jan 8, 2010 | 11:21 AM
Diesel Nut's Avatar
There is nothing about a headgasket job that is cheap. Thats just a fact of life there. Next, it will be very difficult to do this job yourself unless you have a lift to pull the cab, or plan to pull the motor.
We use stock Ford gaskets with ARP studs, of course after our machine shop has given the heads a clean bill of health and a nice surface job.
Next, you will need several gasket kits from ford, to cover everything you took apart. If you don't have a means of testing the oil cooler, I HIGHLY recommend you replace it. Its not too expensive. Next, you need to test the EGR cooler to insure its not cracked.
We can help you out if you hit any snags.
Old Jan 8, 2010 | 11:46 AM
BC06PSD's Avatar
Stick with the ford gaskets and have your heads checked out. Don't buy into fire ringed gaskets since so many people have had problems.
Old Jan 10, 2010 | 12:15 PM
spindrift's Avatar
I don't believe you can purchase the Ford OEM head gaskets by themselves. More likely they come in an upper gasket kit, which includes the head bolts. This makes buying the gaskets expensive. I'd go with the black onyx set which you should be able to find for $200-$225.
Old Jan 10, 2010 | 11:40 PM
Mdub707's Avatar
You can also get an oil cooler rebuild kit instead of buying an entire new cooler. I would do that. Also do an EGR full delete while you've got it apart.
Browns diesel has always been the cheapest places for ARP's. I got mine last summer $385 shipped to my door.
Old Jan 20, 2010 | 01:49 PM
grabber1's Avatar
Iam new to the site but was wondering what it means exactly to delete the EGR. What are the pros for doing this??
Old Mar 13, 2010 | 02:38 PM
2007F350HD's Avatar
hey guys, not to jump on someone else's post (sorry M/T) but it was said that are problems with fire ringing? What kind of problems? Thanks all.
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
turbodiesel123
Nov 28, 2014 08:36 PM
HE22871
Nov 26, 2014 03:15 PM
Hardcorefx4
Oct 6, 2014 07:47 PM
LemayAutoCare
Price Quote - Request A Price
Oct 1, 2014 08:28 AM
