fuel lines
Old Jan 8, 2010 | 08:46 AM
jshafley's Avatar
Default fuel lines
my fuel lines are rotted out should i replace them with the same size lines or should i go thicker? i do plan to replace my pump to eventually too but my lines are leaking pretty bad now so I'm just doing the lines for now.
Old Jan 8, 2010 | 08:48 AM
Whit's Avatar
Site Mascot
go half inch fuel rated hose
Old Jan 8, 2010 | 08:59 AM
12vcummins96's Avatar
whit thats pretty big for stock the fittings are only 3/8 if you are planning on bombing the truck then i would get a fass or airdog they come with the 1/2 fuel line from tank to pump
right now with the stock line everywhere else its not going to help you by putting that size line on
Old Jan 8, 2010 | 09:05 AM
Whit's Avatar
Site Mascot
yes .....it would require new fittings too....I would look at the fittings and line then yer upgraded there for future
Old Jan 8, 2010 | 09:11 AM
yeah thats true to if you wanted to do that it would be good so that way if you only wanted to put a pump on it then you would already have the fittings there
Old Jan 8, 2010 | 09:53 AM
NadirPoint's Avatar
Stock is 5/16". 3/8" is plenty for any HP you will ever get out of a 1st Gen. Stainless seamless 3/8" tubing is not that expensive, couple bucks a foot, maybe.
Old Jan 8, 2010 | 11:07 AM
jshafley's Avatar
so an air dog pump comes with the lines too?
what am i looking to spend on the pump and lines set? and where should i get it?
Old Jan 8, 2010 | 12:32 PM
tltruckparts's Avatar
yes the air dog pumps come with everything including fitting and gas line.
as for where to get it at, post under the request a price quote area on here. sponsors can take care of you.
ardig 100 or 150's normally go right around 500-520, and the airdog II goes for right around 600
Old Jan 8, 2010 | 05:19 PM
weems04's Avatar
Are you talking about the metal lines from the tank to the front? mine are rusted and leaky aswell. do you just buy the metal line and bend it yourself? if so were do you get it?
Old Jan 8, 2010 | 07:14 PM
seandonato73's Avatar
just ordered my air dog II 165 from diesel auto power..... $599 shiped as far as i'v been told it comesw with everything you need.... 1/2" fuel line in take moduel, everything..... it's worth the $599.....
oh an to the guy that doesn't thing first gens benifit from 1/2, what makes you say that, 1/2" is a standard upgrade... flows way more fuel....aome of us ARE pushing a lot of fuel to our trucks means we need more flow 1/2" means more flow... i loose fuel press at half throttle with my 95gph fass..... so 1/2" isn't a waste
