6.0 Powerstroke Blue smoke
I have seen two 2005 or so 6.0 Fords this week just Billowing the blue clouds of smoke both of them is while the engines are just started and not at idle but after taking off normally down the road then it clears up. Turbo oil Seals? Any input would help.Thanks
I had the same issue on a 03 and I was told to that the drain tube on the turbo doesnt drain fast enough on the older 6.0 and causes it to bake the seals right out if you put the 07 upgrade drain tube I also did the Icp sensor while i was in there
gagemotors
Jun 9, 2015 04:24 AM
