What turbo is this?
Old Jan 6, 2010 | 03:14 PM
Bad93Cummins's Avatar
Default What turbo is this?
Its a Garret turbo. this is all I could really find on the turbo A/R .55(I think) B/P M-43
Thanks
Old Jan 6, 2010 | 04:11 PM
seandonato73's Avatar
does it have any sort of numbers on it?
Old Jan 6, 2010 | 07:12 PM
Alwaysworking's Avatar
the comp wheel is a 60/80mm and the turbine wheel is 65mm, i have that turbo, they have a t-4 foot its is about 14cm with a dual port w/g.
i'm running one on my truck right now with a modded exhaust housing.
mine came off an 7.8 international
Old Jan 6, 2010 | 08:43 PM
alwaysworking whats the AFC spacer in your sig?
Old Jan 6, 2010 | 08:45 PM
So the turbo that my buddy has is missing the wastegate acutator? So is it worth it to put in my truck?
Old Jan 6, 2010 | 09:58 PM
tower_ofpower's Avatar
you'd have to pruchase an aftermarket exh manifold for it to bolt up being that alwaysworking has pointed out its a T4 flange. and according to his specs it'd be the same as moding your H1C to those specs. main benefit would be the dual port W/G. no uneven manifold pressures between the front 3 and rear 3 cylinders. the turbo would still boast quicker spool up and higher boost numbers. it may be something worth doing but ATS is the only one that i've seen to make a T4 flanged manifold for the 5.9
Old Jan 7, 2010 | 10:11 AM
you would never need the w/g on that turbo unless your way over fueled.
you can modify an exhaust housing off an s200 and have a 12cm w/g housing.
then youd have a 60/65/12 that sounds really good, the housings are not hard to machine.
there are adapters to run the t-4 foot on a t-3 mainifold
Old Jan 7, 2010 | 10:15 AM
cummins_guy's Avatar
there should be a part # on the cartridge.
Old Jan 7, 2010 | 11:47 AM
so the turbo is a 62/65 turbo? Ill try and get some more numbers off of it today.
So I would need to find a S200 to modify the ex. housing and make it a 62/65/12 turbo? Is the turbo worth messing with? Ill be getting pod injector's soon, the guy is shipping them monday, would it be a good turbo with those injectors or no?
THANKS
Last edited by Bad93Cummins; Jan 7, 2010 at 11:47 AM. Reason: Automerged Doublepost
Old Jan 8, 2010 | 12:43 AM
its a 60/65 not a 62
i have a source for exhaust housings if need be.
