Type F in my transmission
Old Jan 6, 2010 | 01:48 PM
Billy D's Avatar
Default Type F in my transmission
I have ran type F trani fluid in just about everything I've ever owned. Any reason why I shouldn't, or can't run it in my trani now?
Thank you
Billy D
Old Jan 6, 2010 | 03:04 PM
blkjack's Avatar
Im not sure I always used what was recommended by the mfg. But here is a link that I found dont know if it will help you out or not but does have some info about trans fluids but no resons why or why not to use one or the other.Automatic Transmission Fluid
Old Jan 6, 2010 | 06:06 PM
Sawman's Avatar
dodge and all mopar product are supposed to run atf+, i am not going to say that is what you have to run but i will say i have had two mopar products (both at the same time and both were gas burners) and tranny shop told me my issues were for running wrong fluid. If that was true it would have been alot cheaper to run the high dallar atf+ over repair shop bill. I am not claiming to know much about this topic, just telling you what happened to me.
Old Jan 6, 2010 | 07:24 PM
NadirPoint's Avatar
Mopar went to a new type clutch material in all the transmissions at some point in the mid 90s. It's OK in up to the A518 or 1st Gen slushboxes, but no later. You will definitely burn it up if you put typeF in a newer transmission. ATF+ Chrysler 7176E spec) is specifically formulated with the correct friction modifiers needed for the new clutch material.
Old Jan 6, 2010 | 08:33 PM
01quadcab's Avatar
I know a few guys running just dex 3
Old Jan 6, 2010 | 09:15 PM
NadirPoint's Avatar
They won't get away with it for long if they tow heavy.
Fluid confusion is the #1 reason for Dodge truck tranny's bad reputation.
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
Brandanllewellyn
Oct 13, 2014 09:34 PM
TheDirtyDozen
Oct 1, 2014 10:09 AM
