Another lift pump question
Old Jan 5, 2010 | 10:50 PM
Cummins01's Avatar
Default Another lift pump question
Well my question is whether or not I need a new lift pump??? I've been reading lots of the threads already posted and it seems that everyone with a bad lift pump has some other problems... The truck runs fine... all the time! Cold weather... everything...
The problem is my fuel pressure gauge reads about 9 or 10 at idle but will drop to 1 or 0.5 lb @ WOT!!
I just rented a mechanical gauge from auto zone and it says about 7 @ idle but will drop to 2 just by stopping the throttle in park sittin in the shop... However like I said never have any problems with any shudder or anything... Runs smooth always fires up immediately when starting it! Also had auto zone scan the codes and the only code was 0234... over boost or something weird, only boosts 26 or 27... But anyway thats another discussion...
Money is very tight so I don't want to just buy a 400 to 500 dollar pump if I don't need to...( If I do have to buy a pump it will definitely be an airdog, fass, or raptor cause someday I plan to take it 500hp...) (and i've heard that stock is junk)
Any Advice??? Thanks!!!
Old Jan 5, 2010 | 11:01 PM
Uncle Bubba's Avatar
If your pressures ever drop below 4psi at anytime you are risking the VP44. This will cost you big money in the end if you wait and still might even if you fix it now. Damage may have already been done.
The stock is only just barely adequate for stock horse powers when everything works perfectly and that's about the nicest thing that can be said about it. Throw it out, fuel lines and all. I would also add the MTUSA belt driven lift pump to your list of pumps to be considered.
Hook up a pressure gauge ASAP that you can see at all times. You can do this for less then $50 for a mechanical gauge and they are preferred anyway over electronic.
Old Jan 5, 2010 | 11:28 PM
01quadcab's Avatar
order a raptor for a vendor on here and be done and hopefully save your vp but if you don't act soon you will need a vp and a raptor
Old Jan 6, 2010 | 01:14 AM
firstdiesel's Avatar
i had the same problem, your pressure sould never go below 5psi at WOT. Get a new lift pump(AIRDOG). Unless you want to buy a VP44 and lift pump when it doesent run. Save your self the cost of the VP and upgrade the lift pump.
Old Jan 6, 2010 | 07:00 PM
Cummins01's Avatar
Thanks guys!
Was afraid thats what i would hear! Just thought maybe there was another problem since everything worked well!!!
Anyway... Between the the Raptor 150, the Airdog 150, and the Fass 150 which is best?
I am leaning towards the Airdog or Fass cause of the 2 filters and how easy they are to change... Raptor doesn't have those i understand???
Meanwhile i will gingerly drive the truck and try to stay above 5 psi.
Another question... Uncle Bubba u say damage may already b done to the VP?? Is there a way to check that to see if its ok?
Old Jan 6, 2010 | 07:07 PM
Only way to check for sure would be to have the pump bench tested. Your truck will drive just fine with no lift pump at all, this is why the gauge is so important. Your VP could also run just fine if it's goin bad. Some things you may notice is decreased fuel mileage, low on power, hard starting when warm, rough or erratic idle and few hundred other things. The one thing you can count on is that if damage is already done it will get worse with time.
I wouldn't worry to much about the VP right now and focus your funds and time on getting the LP and fuel supply fixed up first.
Old Jan 6, 2010 | 07:12 PM
seandonato73's Avatar
i have a fass on my first gen...not impressed i just bought a airdog II 165, comes with everything you need, even the stuff for in your tank. and the damage uncle bubba is talking about is a diagham in the VP if the fuel press. goes too low you will strech it and risk putting stress cracks in it which will lead to it breaking.....
feel free to correct me if i'm wrong i don't know a whole lot about 24v
Last edited by seandonato73; Jan 6, 2010 at 07:12 PM. Reason: Automerged Doublepost
Old Jan 20, 2010 | 11:46 PM
Cummins01's Avatar
Well I just got my brand new Raptor 150 put on... And it isn't pumping fuel!!!!!!!!!!!!!
Tried pressurizing the hang out of the fuel tank, Can get fuel to go through it then but as soon as I let the pressure off the fuel tank it quits coming!!!
It seems like it isn't sucking it out of the tank.
ANY HELP???? PLEASE!!!
Old Jan 21, 2010 | 12:52 PM
01quadcab's Avatar
was your truck fitted with an in tank pump? If so you gotta drop the tank and do a draw straw, or sump it.
Old Jan 21, 2010 | 01:37 PM
NadirPoint's Avatar
Assuming everything's installed correctly () sounds like a restriction somewhere. What about the filter?
