Glow shift gauges.
Old Jan 4, 2010 | 09:33 PM
slosh2500's Avatar
Default Glow shift gauges.
Anyone have any experience with installing these brand? I got the whole kit with pillar off a friend who never put them on and sold his truck. Its the boost, tranny temp and egt. Whats the best mounting place's? And does the trans temp just mount in the side of the pan? Thanks
Old Jan 4, 2010 | 09:45 PM
Sawman's Avatar
don't no about tranny temp but i am very happy with my boost, fuel pressure, and egt gauges
Old Jan 5, 2010 | 06:33 PM
slosh2500's Avatar
i guess you had to supply your own wire to connect the sensors with the guages ? Also does the tranny temp just go right into the side of the pan?
Old Jan 5, 2010 | 07:19 PM
12vcummins96's Avatar
if you have a aftermarket pan then yes if not either you will have to weld a bung in the pan or put it inline
Old Jan 5, 2010 | 07:26 PM
Sawman's Avatar
Glow shift sent a wiring kit to me but the only wire i used was one to fuel sensor, and two wires for power for the lights in gauges. What series of gauges do you have black, white, or 7 color tinted gauges?
Old Jan 5, 2010 | 09:30 PM
slosh2500's Avatar
the black 7 color. I meant to get from the supplied wires to the sensor. Back of the guage has about 1ft of wire and same on sensors. I just going to drill the pan for the sensor and braze a nut on it.
Old Jan 5, 2010 | 10:46 PM
01quadcab's Avatar
you can also put the sensor in the rear test port on the trans like the edge instructions state. This is where i have mine. less mess too
Old Jan 6, 2010 | 05:29 AM
slosh2500's Avatar
Where is the rear test port? Also is there a factory temp place where this could go? i think my factory failed me because when the tranny was burning hot the light naever came on. Thanks for the help
Old Jan 6, 2010 | 10:42 AM
01quadcab's Avatar
it's on the passenger side rear of the trans you pull the bolt/plug and put the temp sender in there. I can't get the edge manual to open from online, it has a nice picture there.
There is no place as far as I know to get the temp from the trans like the factory unless your running a scan tool the whole time. do you know how hot your trans got? 250 is when the light should come on and you will have no overdrive
Old Jan 6, 2010 | 03:50 PM
NCFPD's Avatar
does the OD autamaticly shut down
