not full potential
Old Jan 4, 2010 | 07:36 PM
dirt diggler's Avatar
Default not full potential
well the truck in my sig does not seem quite rite whith the waste gate pluged im only able to hit 30lb boost whitch is fine. Because of it only being an hx 35. But i figured i should not be abble to clear up the smoke on the hot unlock whitch i can. An the truck on the top end feels like its surging because of lack of fuel?? Had fuel press checked its good also checked for boost leaks foun some i fixed them im stuck on where to go know. My 150 nozzles were also pop tested befor i installed them. Or am i just asking to munch for what iv got i also noticed that my clutch seemed to slip a lot quicker than it does now? thank for eny info sorry about the spelling buy the way it has a new fuel filter.
Old Jan 4, 2010 | 09:14 PM
DB Admin's Avatar
Banned
Call me , your phone busy
Old Jan 4, 2010 | 09:17 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i will check tomorrow and see if brian has any turbos layin around
Old Jan 4, 2010 | 10:44 PM
thank ya pap
Old Jan 4, 2010 | 11:35 PM
With the Wastegate Closed you should be getting much more than 30psi. I can hit 45psi with only the Adrenaline and stock injectors with my HX35.
Old Jan 4, 2010 | 11:55 PM
NCFPD's Avatar
How do you check for boost leaks
Old Jan 5, 2010 | 12:47 AM
Uncle Bubba's Avatar
https://www.dieselbombers.com/dodge-...tructions.html
Old Jan 5, 2010 | 03:57 AM
NCFPD's Avatar
ok thats freakin nifty thanks bubba
Old Jan 5, 2010 | 06:14 AM
12vcummins96's Avatar
sounds like your wastegate is still leaking by if you fixed your boost leaks
Old Jan 5, 2010 | 10:34 AM
5th-wheeler's Avatar
Default getting anywhere
any luck
