No Lights please Help
Old Jan 4, 2010 | 07:15 PM
Randy4541's Avatar
Default No Lights please Help
Ok guys i got a new head light switch today but thats not the problem. I check my fuse box and i got no power to 3 fuses wich are tail stop, horn and lights got no power. I check for bad fusible link with a tester and they are all good. Can any 1 give me a hand so i can fix this ploblem Please Thank You
Old Jan 4, 2010 | 07:19 PM
12vcummins96's Avatar
check grounds
Old Jan 4, 2010 | 07:26 PM
Randy4541's Avatar
I did check the grounds. I got no horn no Lighs no stop lights
Old Jan 4, 2010 | 08:07 PM
tltruckparts's Avatar
start by pulling out the light bulb connector on one of the headlights and check it for juice when you turn the headlight switch on. if you have juice but no lights, then either the bulbs are all bad (not likely at all) or you have no ground. if you dont have anything, then you have something inbetween the switch the wires themselves.
Old Jan 4, 2010 | 08:12 PM
Randy4541's Avatar
I got no juice going 2 the fuse in the fuse box
Old Jan 4, 2010 | 08:43 PM
well there ya go. track down why. check a wiring diagram and check continuity from that 12v in on the fuse block to wherever it comes from. also check all plugs ive had stuff like that happen from an old plug seperating or something like that
Old Jan 5, 2010 | 10:13 AM
cummins_guy's Avatar
Chilton book at autozone has a really good wiring diagram for your problem, if you want i can scan one out of my books and send it to you VIA email, just give me your email.
Old Jan 5, 2010 | 10:25 AM
TAKING WIFE TO STORE, HIT A BUMP, WIFE ASKED "WHAT WAS THAT" I SAID " A HONDA
thats freaking hilarious
Old Jan 5, 2010 | 05:07 PM
Randy4541's Avatar
Thank u all for the help found the problem it was the wires that go down by the emergency brake and out the fire wall. Every time the emergency brake got set the wires were 2 close to it so they wore out and broke.
carid
Diesel Bombers Sponsors
May 7, 2015 06:40 AM
carid
Apr 15, 2015 07:29 AM
carid
Jan 6, 2015 06:28 AM
bypass-21
Jan 3, 2015 04:47 PM
carid
Nov 10, 2014 02:15 AM
