Removing Transmission
Old Jan 4, 2010 | 06:48 PM
haulitrite's Avatar
Default Removing Transmission
This may be a dumb question, but how to I pull the TC bolts off from the flywheel.
Old Jan 4, 2010 | 06:52 PM
12vcummins96's Avatar
on the right side there is a cover held on by 2 10mm bolts take that off and you can get to the torque converter bolts
Old Jan 4, 2010 | 06:56 PM
haulitrite's Avatar
that was easy, thanks
Old Jan 4, 2010 | 06:58 PM
greenmonster's Avatar
If i remember right. u can access the nuts between the hole for the starter and the block of the engine but its tight, so dont pass it up.
Old Jan 4, 2010 | 07:01 PM
no problem thats what we are here for
Old Jan 5, 2010 | 07:27 AM
STUMPMAN's Avatar
Don't get your gear wrench stuck in there
Old Jan 5, 2010 | 10:06 AM
440ctd's Avatar
Its all on the pass. side the baring tool hole if you have one and also the hole to access the torque converter bolts. I believe there are 6 that hold the torque converter in. I went around and around a couple times just to make sure they were all out. good luck pulling it you have to drop the cross member to make it easy. I dropped mine like 4 inches and squeezed the transmission in and out. good luck
took me a couple days to get the old one out and the jasper in. but that was working after a full day of work
Old Jan 5, 2010 | 10:11 AM
96blackcloud's Avatar
once the acess panal is off if i remember right the tq bolts are 16mm
Old Jan 5, 2010 | 11:03 AM
440ctd's Avatar
they vary my jasper ones were 15 and the ones before were 16mm
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
SixSpeed
Jan 11, 2015 01:41 AM
W350-4x4
Nov 12, 2014 09:35 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
