fuel pressure
Old Jan 4, 2010 | 12:53 PM
jake 94's Avatar
Default fuel pressure
what should my fuel pressure be at on my truck?
Old Jan 4, 2010 | 01:14 PM
PhilipR's Avatar
stock.....17psi at idle and 30 or so while cruising. With your mods....40psi would be a good number to look for but you'll have to shim the OFV spring or go to an aftermarket pump like a FASS or Airdog.
Old Jan 5, 2010 | 07:26 AM
STUMPMAN's Avatar
My truck would run with 2-9 psi before I removed that junk a$$ lift pump and replaced it with a real one. I drove it a long time w/ that low pressure.
Old Jan 5, 2010 | 07:40 AM
R&RDiesel's Avatar
FormerVendor
Wow i am suprised it ran with those low numbers. With a p-pump higher flow is better, if or when you get a different pump, dont be shy to look at something that puts out 40-50 psi, those p-pumps love high fuel pressure delivery especialy when modded.
Dbleo351
Nov 20, 2016 09:34 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
cummins Pride
Oct 6, 2014 11:28 AM
