rear axle replacement
Old Jan 3, 2010 | 09:55 PM
luke46's Avatar
Default rear axle replacement
This seems like a stupid question my one ton dually has 4.10 gears the axle is starting to growl and got some small metal in the oil I just changed it again today and lots of little flakes. Time to start looking for new. I'm near el paso lots of junk yards. What axles will work. Is a single wheel the same as dually rear? 3/4 ton 1 ton? I'm sure I have the 80 being a one ton dually what different years can I use. I can cut and remount axle perches been there and done that on my rock crawlers. Just want the same size yokes. A direct drop in would be easiest but I don't mind a little work. I think I would like 3.73 gears even though they didn't come in these years. I think 3.55s might hurt me too much I do some heavy hauling truck is work 75% of the time I have a car for a daily driver. thanks for any advice
Old Jan 4, 2010 | 10:59 AM
Jolleyman's Avatar
Unless the housing is bent, why don't you just have the ring and pinion replaced?
Old Jan 4, 2010 | 02:41 PM
luke46's Avatar
I thought about it and still might but around here you can get axles cheaper a lot of tthe time
Old Jan 6, 2010 | 02:14 AM
guesswho512's Avatar
around here, in oklahoma, it is only cheaper if you get a pick-a-part. most people want 600-1000 for a 1ton axle. i got one from local yard for 130 out the door, but i pulled it.
this is where i learned about my dana 80
Dodge Ram Dana 80 Axle Specifications
Old Jan 7, 2010 | 09:23 PM
luke46's Avatar
OK that gave me about everything I need to know thanks. And ya I'm doing u pull it and now that my vehicle speed sensor just quit guess I'll be going here shortly so I don't have to buy extra parts.
Machinist
Jun 23, 2015 06:57 AM
May 31, 2015 08:10 AM
jwrbtsn
Jan 19, 2015 04:08 PM
Dec 19, 2014 02:30 PM
natenel1
Oct 26, 2014 03:09 AM
