Rear main seal
Old Jan 3, 2010 | 07:28 PM
haulitrite's Avatar
Default Rear main seal
I have been trying to find a link (With pictures) but have found two different answers on how to replace the rear main seal.
I have a 94 CTD so from my understanding all I have to do is pull the trans and pull the seal.
is that correct?
Old Jan 3, 2010 | 08:35 PM
ArizonaRedneck's Avatar
https://www.dieselbombers.com/24-val...rear+main+seal check this out and see if it helps with your question
Old Jan 3, 2010 | 09:04 PM
FastCR's Avatar
pull trans, remove flexplate, remove seal, install new seal, done.
Old Jan 3, 2010 | 10:03 PM
cummins95's Avatar
might wanna reinstall the flexplate n the trans before your done
Old Jan 3, 2010 | 10:53 PM
Lil Red Express's Avatar
take 2 small self taping screws and screw them into the old seal opposite of each other and then use vice-grips to pull the seal. I broke a seal puller on my old 97 trying to pull it out.
Old Jan 3, 2010 | 11:02 PM
FastCR's Avatar
touche
make sure you don't put them in too far out from the center, I screwed up and marred the metal a bit, but not enough to leak.
Old Jan 3, 2010 | 11:09 PM
Ya I should have mentioned that, since I did the samething Just pay attention to the position of the screws.
Old Jan 4, 2010 | 07:18 AM
STUMPMAN's Avatar
I did mine, its pretty easy, especially if your used to a gasser. I was amazed, and thought "Man I love this Cummins" I used a slide hammer and popped it right out.
shingi
Off Roading
Sep 30, 2015 11:17 AM
yfzrunner
Sep 17, 2015 05:23 AM
Machinist
Jun 23, 2015 06:57 AM
Max713
Apr 17, 2015 01:20 AM
wildbill
Jan 31, 2015 11:14 AM
