Retorqueing head bolts?
Old Jan 3, 2010 | 12:25 PM
DieselPerformanceGuy's Avatar
Default Retorqueing head bolts?
Hey all,
i have a question about retorquing the head bolts. I did the ones that i could get to without taking anything off,(2,3, and 6 cylinders, and all the ones below them under the exaust manifold) i got those ones to 125 ft lbs. I figure those ones could help a little till i get the rest torqued down this spring. Can i still drive it like this or should i finish them off.
thanks for any help.
Old Jan 3, 2010 | 02:14 PM
RSWORDS's Avatar
You need to do them all. The reason you tq head bolts (and studs) down to equal amounts and one of the reasons its so important is because you need to hold teh head down equally, with out you will create "weak" spots in the head gasket.
Old Jan 3, 2010 | 03:49 PM
ok thats what i just did the more i got to thinking about it i decided to do them all.
Old Jan 4, 2010 | 09:58 AM
cummins_guy's Avatar
cylinder head torque specs
66, 89 ft/lbs +90 deg
doing them a 125 will not hurt the engine, but you will have to replace them, they are now T/Y
Old Jan 4, 2010 | 02:23 PM
what does t/y mean
Old Jan 4, 2010 | 02:26 PM
Torque to yield
It is the stress point for the bolt, once you go to that it is highly recommended that you replace if you ever remove the bolts or if the bolts come loose on their own
Old Jan 4, 2010 | 04:07 PM
RSWORDS's Avatar
135 ft/lbs is common practice for holding down the head on budget trucks with high cyl pressure and yes at these levels do not reuse bolts.
Old Jan 4, 2010 | 04:27 PM
Well i really didn't need to even retorque them but i decided it was insurance. I'm only pushing 28-29 psi of boost right now.
Old Jan 5, 2010 | 06:28 AM
The bolts are pretty cheap, so no to worry to much.
I do the same on mine, just wanted to stress the point about reusing bolts, I have seen some pretty nasty stuff done to guys who reused.
Old Jan 5, 2010 | 09:25 AM
ok thanks man
