still none
Old Jan 2, 2010 | 04:44 PM
jake 94's Avatar
Default still none
got my new clutch in and everythong slid forward and still i have no black smoke at all at all and its low on timing can someone help me out please
Old Jan 2, 2010 | 04:48 PM
12vcummins96's Avatar
have u tuned the afc
u have none at all well thats good its a perfect setup
smoke is wasted fuel
Old Jan 2, 2010 | 04:53 PM
jake 94's Avatar
i love the smoke though its so purtty ha
havnt tuned afc yet
Old Jan 2, 2010 | 04:56 PM
the afc will give you smoke turn the star wheel towards the motor and you will get smoke
Old Jan 2, 2010 | 04:59 PM
jake 94's Avatar
sweet deal also will i get some more when i adjust my timing?
Old Jan 2, 2010 | 05:12 PM
R&RDiesel's Avatar
FormerVendor
You might get a little when adjusting the timming but dont count on it. But if it is low you deffinetly need to adjust it. For A street truck i would recomend putting it at about 16* advanced. Thats going to put you in a good spot to start tunning your pump. Also if you do all of this and still no smoke, try checking the rubber plunger in the afc that controls your fuel, sometimes they rip and dont allow the pump to give full fuel. Good luck.
Old Jan 2, 2010 | 09:20 PM
monster12valve's Avatar
u have a fuel issue... i slid the factory plate foward and had smoke.
u have ddp3, and a 5plate. u have delivery issue.
also with factory dv's ur not gettin the most out of your ddp3's or ur turbo
Last edited by monster12valve; Jan 2, 2010 at 09:20 PM. Reason: Automerged Doublepost
Old Jan 2, 2010 | 11:19 PM
jake 94's Avatar
So then that's not a good thing for me do I need to tear it apart?
Old Jan 3, 2010 | 08:26 AM
do u have factory dv's? if you do then i would get some dv's cause the turbo is prob cleaning up all the fuel.
Old Jan 3, 2010 | 12:26 PM
R&RDiesel's Avatar
FormerVendor
Check the rubber diaphram inside the afc before you tear it down.
