24v power steering pump on a 12 valve?
Old Jan 2, 2010 | 04:40 PM
tltruckparts's Avatar
Default 24v power steering pump on a 12 valve?
hey guys i am in need of replacing ym power steering pump, and since i have hydroboost, im trying to eliminate my splicing for the return lines
well on a 2001 24v truck with hydroboost, it looks like an identical pump, mounting and everything, except for the fact that its got a 2nd return line
anyone know if a 24v power steering pump will fit a 12 valve casing? thanks
also the 12 valve 94-98 cummins uses the same part number as the power steering pump on the 2001 24 valve. so since theyre the same, im guessing theyd go on a 1st gen 12 valve as well
Last edited by tltruckparts; Jan 2, 2010 at 04:40 PM. Reason: Automerged Doublepost
Old Jan 2, 2010 | 04:42 PM
12vcummins96's Avatar
it should work
Old Jan 2, 2010 | 04:46 PM
thats what im thinking too i just hope someone knows before i go spend 100 bucks on one to find out it doesnt fit
Old Jan 2, 2010 | 04:50 PM
is the pump you have set up for hydroboost
Old Jan 2, 2010 | 04:53 PM
no its just a stock 93 normal vacuum pump, but my truck has hydroboost so i had to splice two return lines together to go into the one return line. my main worry is if the shaft that spins is the same and if it will bolt up the same.
Old Jan 2, 2010 | 04:55 PM
yeah that should be the same
Old Jan 2, 2010 | 07:06 PM
440warwagon's Avatar
If all you need is a second return line just use the pump reservoir off of a hydraboost gm pump on your existing pump.They are both Sagnaw parts and should work.
Old Jan 3, 2010 | 01:09 AM
well i needed a new pump regaurdless, i took my 93 pump in and got a 97 hydroboost pump and compared the two, they look to be 100% identical, so if anyone ever wants to install hydroboost, a newer pump should workl
b&hbiz
Sep 9, 2015 07:53 AM
ctjkelley
Jun 3, 2015 06:01 AM
ramrunner01
Jun 1, 2015 12:10 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
