need to buy pistons
Old Jan 1, 2010 | 11:12 PM
high line's Avatar
Default need to buy pistons
286110? bigger bowl with low ring lands. a little lower comp. what you guys think .016 155 angle injectors?
Old Jan 4, 2010 | 09:16 AM
Smokem's Avatar
Going to use a marine nozzle?
Old Jan 4, 2010 | 10:25 PM
high line's Avatar
i think so not sure yet, block is getting hot tanked have some time to decide on piston and injectors. New to cummins engines, i have tried to read up and read between bs.
Old Jan 5, 2010 | 09:34 AM
cummins_guy's Avatar
If this is for marine, the best piston (my opinion ) 3911400 Cummins
Old Jan 5, 2010 | 10:14 AM
Smokem's Avatar
Application? Need a bit more information to make a suggestion.
Old Jan 5, 2010 | 07:48 PM
high line's Avatar
non daily driver benched pump oring head twins. i have a large primary turbo already 3.25 inducer. engine will repower an f250. appreciate suggestions, id like to view some mahle piston diagrams.thanks
Old Jan 8, 2010 | 01:02 PM
Smokem's Avatar
The more detailed you are, the better the suggestion will be. Drag racing? What model benched pump? What twins(housings)? Timing range? Hp goal?
Old Jan 9, 2010 | 12:44 PM
high line's Avatar
just a hot rod, the pump is a 180 cpl 1863. the garrett t 18 has a 1.13 ar on turbine. not sure how much timing to run. shooting for around 700hp. havent got a small turbo yet or injectors. just got block back home from machine shop hot tanked and decked.
mild porting on head in bowl area gonna have a performance cam also
Old Jan 9, 2010 | 07:01 PM
Smokem's Avatar
That Garrett T18 is old school Caterpillar, 86/111mm turbine, I would find something different. If you plan to run much timing, keep a 145° injector, for the price the 286110 is going to be hard to beat.
Old Jan 10, 2010 | 11:43 PM
high line's Avatar
mesured comp inducer 82mm gonna try running it. its new and in my garage, had it for some time. whats cr ratio of the 286110? or am i better of with the 286050? gonna run 145 angle sdx injectors but havent decided on size. im thinking .016. turbo is an a40 model also.
