Getrag Grinding
Old Jan 1, 2010 | 07:15 PM
weems04's Avatar
Default Getrag Grinding
help please. My 90 250 5 speed shifts up 1 through 5 perfect and flawlessly, however on the downshift it grinds going into 4th and then into 3rd. if i slow down and slowly ease into these gears sometimes they shift fine. would this be the synchros? it only does it on the downshift side. upshifts fine. I just replaced the fluid with 5 quarts 5w-30 synthetic. thanks much.
Old Jan 1, 2010 | 07:36 PM
big bad diesel 416's Avatar
Site Sponsor
have you tryed to doubble clutch it ?
and a perfict down shift is hard to master from the years i drove semi i dont use the clutch for an up shift or a down shift just the right amount of throtle but it sounds like the trany is fine
Old Jan 1, 2010 | 08:41 PM
tltruckparts's Avatar
could your clutch not be engaging 100%? just enough to where when its all the way in gear it snags just the slightest bit?
or possibly your trying to downshift into a lower gear too soon before the tranny wants to
Old Jan 2, 2010 | 12:02 PM
weems04's Avatar
Well dont know for sure but i dont think its the clutch because it does the same thing when i dont use the clutch at all on the up shift or down shift. shifts up perfect and grinds third and fourth on downshift with or with out clutch.
Old Jan 2, 2010 | 08:36 PM
Site Sponsor
sounds like your shifting too soon every thing seams fine
Old Jan 2, 2010 | 08:58 PM
olbetsy98_12v's Avatar
A friend of mine had the same problem and it ended up being the synchros.
Junior122
Jan 13, 2021 06:30 PM
mr. dune-a-holic
May 4, 2015 01:39 PM
garbuster
Mar 18, 2015 02:16 PM
Jordan1233
Nov 20, 2014 12:34 AM
wvwelder89
Sep 28, 2014 02:23 AM
