harmonic balancer problem
Old Jan 1, 2010 | 01:34 PM
1stgenSWB's Avatar
Default harmonic balancer problem
Hey guys Happy new year to all of you.....
Ok here is the thing, about a month ago a weird noise was coming out of the belt tensioner,so i headed to the local shop and bought a new BT and also new belt,i think the problem got solve at that point.
So this morning i started my 91 and there goes again the rattling noise coming out of the new belt tensioner, i took a closer look and notice that the Harmonic balancer was dancing all over, took a closer inspection on the 4 bolts, they were not the problem (not loose) at this point only 2 things came to my mind,HB sometimes can crack or separate, right.?..how dificult is for a diesel amateur like myself to remove the HB? a closer and deeper inspection at this point is a must....thanks for your help and time.. Gilberto
Old Jan 1, 2010 | 01:42 PM
BC847's Avatar
There are four bolts that fasten the HB to the crankshaft snout. Very easy to remove as it's not pressed onto the shaft like a SB 350 for example.
Old Jan 1, 2010 | 02:07 PM
tltruckparts's Avatar
yep exactly. four bolts and it slides right off
Old Jan 1, 2010 | 04:03 PM
1stgenSWB's Avatar
well...!i think i found the problem,The rubber does not look good at all, but that's not all, Apparently there's a good chance that a crack that has been developed between 2 of the 4 bolt holes......
any ideas guys?? how much is a new damper? where can i look for one....thanks.
Old Jan 1, 2010 | 04:31 PM
RSWORDS's Avatar
I know some of our sponcors can get you a replacment from a stocker to an aftermarket performance one!
Old Jan 1, 2010 | 05:08 PM
1stgenSWB's Avatar
will it be a big, big, big difference money-wise going from a stock one to the Performance one.... gilberto
Old Jan 1, 2010 | 05:22 PM
RSWORDS's Avatar
Do Not Know...
Old Jan 1, 2010 | 09:41 PM
stillcummin's Avatar
oh yes! fluidampr,some ar big bucks
Old Jan 1, 2010 | 10:52 PM
1stgenSWB's Avatar
what about the one from ATI?
no worky......
Old Jan 2, 2010 | 10:23 AM
any aftermarket unit is gonna be bigbucks
