5-sp shifting issues
Old Jan 1, 2010 | 12:34 PM
cravenford's Avatar
Default 5-sp shifting issues
This '89 D250 is my third Dodge Cummins, and my first with a manual transmission. The truck has only 93,000 miles on it, and the original owner said Dodge recalled it when it had
4x,xxx miles to replace transmission, clutch and pressure plate. I'm ignorant as to why the recall occurred. Anyway, having no experience with these manual transmissions, it seems that this one is pretty hard shifting - you can shift easily from 4th to 5th, but 2-3 is very slow and often will either grind or bump hard if I try to shift with what I'd consider a normal speed, and 3-4 is slow, but a bit faster than 2-3. Am I expecting too much, or is there something that needs to be done to make shifting a little faster and easier? I'll appreciate any help.
Old Jan 1, 2010 | 01:03 PM
Richie O's Avatar
2 3 is a harder shift on mine too.
Old Jan 1, 2010 | 01:57 PM
RSWORDS's Avatar
Is there a different fluid you could run for a better shift Richie? I dont know much about teh rags...
Old Jan 1, 2010 | 05:38 PM
big bad diesel 416's Avatar
Site Sponsor
over fill by one quart and a good synthetic 5w 30
Old Jan 1, 2010 | 06:08 PM
tltruckparts's Avatar
do they use 5w-30 or gear oil?
Old Jan 1, 2010 | 07:06 PM
weems04's Avatar
I Know the shop manual calls for 10w-30 for what its worth.
Old Jan 1, 2010 | 07:38 PM
Site Sponsor
5-30 no gear oil to thick
same idea the 5 just flows better when its cold
Last edited by big bad diesel 416; Jan 1, 2010 at 07:38 PM. Reason: Automerged Doublepost
Old Jan 1, 2010 | 08:05 PM
NadirPoint's Avatar
Synchromesh makes them shift much better. It's close to the same viscosity as 5-30 motor oil but with the necessary FM formulation to let the synchros do their job better. In any case, the Getrag does not like to shift quickly. At least half your problem is probably technique.
The recall was probably for one of the the runs that came shimmed too tight from the factory.
Old Jan 1, 2010 | 08:38 PM
so 5-30 synthetic is the way to go on these huh?
Old Jan 1, 2010 | 09:01 PM
cravenford's Avatar
Thanks for all the input; by the way, what is 'Synchromesh', and where do you get it? That is a product that I'm not familiar with. And how do you overfill the transmission by one quart?
