kdp help
Old Dec 31, 2009 | 01:30 PM
jrad989's Avatar
Default kdp help
doin headgasket and some stuff and took my front cover and my kdp was already tabbed. then i noticed the timing case is cracked pretty bad and jp weld over it as a fix. what the worst that could happen with that crack?
Old Dec 31, 2009 | 02:44 PM
captain_stabbin's Avatar
does it leak oil ?
Old Dec 31, 2009 | 04:01 PM
prromine's Avatar
You need to change the housing. When it breaks up top, it also breaks around a bolt above the crankshaft timing gear. If that bolt comes out you are SCREWED.
If I can find my housing I will post a pic or two.
Old Dec 31, 2009 | 04:25 PM
cummins95's Avatar
i just had my casing welded by a teacher down at school, n put red loctite on all the bolts that are inside casing. didn't really see the need to buy the $280 case when mine was repairable
Old Dec 31, 2009 | 07:31 PM
jrad989's Avatar
well it does leak a bit of oil i always just thought it was a gasket. its just from where to two broken pieces are together and the gasket is so thin it doesnt seal it. its been sealed up pretty good. i cant see repalcing and re-timing everything it cus its been like that for a while.
51Hudson
10
Aug 5, 2015 12:32 AM
quiksilver1j
Jul 30, 2015 12:41 PM
xj_crawler
Nov 20, 2014 12:28 PM
