Stealth Plate Install
Old Dec 29, 2009 | 10:32 PM
Whit's Avatar
Site Mascot
good job bud.....thanks for the nice write up with pics.....this will help many in diesel land
Old Dec 29, 2009 | 10:39 PM
RAW's Avatar
RAW
Your opinion on using a test light versus a multimeter?
Old Dec 29, 2009 | 10:41 PM
Whit's Avatar
Site Mascot
absolutly.................not everyone has a multi meter or knows how to use one thats prolly why the instros says to use a test light, but if ya have the equipment and knowlege so much the better
Old Jan 1, 2010 | 12:33 PM
thebullet83's Avatar
don't even own a test light!
Old Jan 11, 2010 | 10:03 PM
Jet A Fuel's Avatar
Thanks for the write up very nice pictures.
Old Jan 12, 2010 | 04:35 PM
slosh2500's Avatar
Default ?
What is the stealth plate good for? Just a better connection between you (chip) and pump or does it help the pump by itself?
Old Jan 12, 2010 | 04:51 PM
Jet A Fuel's Avatar
Someone correct me if i am wrong but when the trucks were new this item could be removed prior to going in for warranty service at the dealer and put the old cover back on and they never know.
Old Jan 16, 2010 | 12:01 PM
Fiveseven's Avatar
Default Extra Turn
I installed a Stealth Plate onto my VP44 over the weekend. I found the instructions straight forward, but did do a couple things differently.
So first and foremost, remove the APPS assembly, and there is your VP44
Remove the 5 screws with the supplied bit.
Install the Stealth plate, and as they say, tighten the 5 screws "snugly"
This is where I did things a little different. The "destructions" say to use a test light to check for power at the Stealth Plate's probe. I never, EVER use a test light on ANY computer circuits. I believe they are for tail lights and such. I used my multi meter to see when power is tapped into, then added my extra half turn.
Snipped the supplied probe from the Edge off, and soldered on eye-lit and heat shrink over the eye-lit and wire protector.
In my opinion, I believe every tapped VP44 should have one of these. No pre-twisting wires to install onto the outside wires of the VP44, and no doubt of a proper connection.
What do you mean by adding an extra turn?
Old Jan 16, 2010 | 12:48 PM
chpmnsws6's Avatar
To ensure proper penetration.....
Old Jan 17, 2010 | 07:38 PM
RAW's Avatar
RAW
The instructions say after power is located on the tapping pin to give an extra half turn on the screw. As is was said above, for proper penetration and connection.
