Speed sensor pics
Old Dec 28, 2009 | 03:19 PM
lcgoatboy's Avatar
Default Speed sensor pics
Issues with speed sensor on my 9th month 91 4X4 Cummins. I've read numeruous posts about some marks,and properly setting of these items up. I can't find any marks or any proper info on this. I have no continuity on the vss,so I'm going to town to get a new one ($105.00can). This all is for the lack of a speedo,no overdrive, no cruise,and most of all me no happy. Want a Dodge ext 4x4 CHEAP?
Old Dec 29, 2009 | 09:31 AM
1st genny nut's Avatar
how cheap?
Old Dec 29, 2009 | 06:42 PM
lcgoatboy's Avatar
$ price went up,the new vss worked but the speedo bounces.It's funny how the ravens hover above the near dead truck .
Old Dec 29, 2009 | 06:46 PM
12vcummins96's Avatar
thats good and bad
Old Dec 31, 2009 | 03:17 PM
chico_mustangs's Avatar
Yeah having no overdrive sucks! At least yours only doesn't work because of a cheap sensor.
Old Mar 17, 2010 | 10:16 AM
orangeamcs's Avatar
Where do I get the reduction unit between the sensor and the gear that goes into the transmission, or what is it called so I can order it from dodge?
Thanks
Old Mar 18, 2010 | 01:46 AM
TXHC's Avatar
AH, that sucks! I fought that damned L-shaped adapter for a couple years on my old '92 first gen. Dealer wanted way too much for it, and nobody else knew where to find one, and half the guys didn't have one on their trucks. I even had an 18-wheeler shop repair mine...lasted a few weeks. Did the same bouncing speedo. Have you tried running the VSS straight to the transmission? I ran around that way...the speedo bounced and was way off, but the cruise control worked.
Part number for mine was #4428549 and was $160 at Dodge dealership. There are 6 different types with different part numbers...each for a specific gear ratio/tire size. They called it the Drive Adapter Assembly. I ended up sending my broken one to a speedometer shop, and they made a new one for like $60.
Old Mar 18, 2010 | 09:00 AM
big bad diesel 416's Avatar
Site Sponsor
think i have a source on these i will know in a few hours
yep got it pm me if you need any parts for it
Old Mar 21, 2010 | 08:01 PM
lcgoatboy's Avatar
My bouncing speedo is fixed now,the plug from the new vss was not plugged in properly.I might add that the vss came with a new plug.
Old Mar 22, 2010 | 09:54 AM
Levi Miller's Avatar
SO did you replacing the sensor also fix the od and cruise because my trucks doin the same damn thing no speedo no od and no cruise its really making me madd butt ima give this a try please let me know if it did fix the od i didnt see anything on here that it did
