tranny shafts?
Old Dec 28, 2009 | 10:30 AM
BAD ASS RAM's Avatar
Default tranny shafts?
i was wondering if i would need to swap shafts if i rebuild a 2 wheel drive 47re for my four wheel drive?
Old Dec 28, 2009 | 01:20 PM
12valvetater's Avatar
I think it's just the output thats different.
Old Dec 28, 2009 | 06:52 PM
6btsmoker's Avatar
The back section is different.
Old Dec 29, 2009 | 07:54 AM
PhilipR's Avatar
Tail housing and output are different.
Old Dec 30, 2009 | 10:41 AM
Diesel Nut's Avatar
AS posted, the tail housing and the output shaft are different, everything else is the same. You will need a press and some special tools to get the overdrive unit apart to swap the output shaft.
Old Dec 30, 2009 | 06:57 PM
6btsmoker's Avatar
The press tool is easy to make with a welder and some 3/8X1 flat stock.
I made one and used it in a trans shop for many years.
Old Jan 2, 2010 | 10:34 AM
how do you make it,i work in a machinery building shop.
Old Jan 9, 2010 | 08:10 AM
6btsmoker's Avatar
I left mine behind at the tranny shop so i cannot measure it.
Very easy to make.Two upright pcs connected to a cross piece in a "U" shape.
Very easy to figure the measurements once the OD shaft is out of the housing.
Old Jan 9, 2010 | 11:16 AM
Diesel Nut's Avatar
4" diameter, 3" ID at bottom, 5" tall.
Next, you will need an old intermediate shaft you can cut down to align the splines up when you put it back together. Without this you will never get the OD unit back on the transmission.
InheritedDiesel
Jun 3, 2015 09:39 PM
wilki
Feb 12, 2015 09:04 AM
Ol Goat
Jan 22, 2015 02:16 AM
B.k. Smith
10
Jan 7, 2015 02:29 PM
Ol' RED!
Dec 11, 2014 10:00 AM
