Rear axle swap
Old Dec 28, 2009 | 08:44 AM
Xforce_nut's Avatar
Default Rear axle swap
I have a couple of question? Can you swap out the rear axle w/ drum brake to an 04 rear axle w/ disc brakes.... are they the same as far as bolting up or not? if they do bolt up the same do i have to swap out the rear gear or not?
The reason i'm asking i found an 04 2500 QC wrecked front collision w/ no motor or tran for a $1000. was just liking to swap out the drum brakes for as cheap as possible. I've done this before but on a camaro.
Old Dec 28, 2009 | 11:37 AM
dieseldocter16's Avatar
2nd gens. also came with disk brake rears. All the auto's built in i believe 01-02 had a disk brake dana 70 rear and I think it was an option on the dana 80's. As far as swaping a rear out of an 04 into your 2nd. gen. I dont think thats gonning to work unless you weld on new spring mounts because the frame are different. I'm also not sure if an 04 rear is wider than a 2nd. gen rear.
Machinist
Jun 23, 2015 06:57 AM
DirtyDiesel58
Jun 7, 2015 11:50 PM
Natenelson1
Jan 19, 2015 07:23 PM
natenel1
Oct 26, 2014 03:09 AM
blakec
20
Oct 18, 2014 03:35 PM
