Brake Problem
Old Dec 28, 2009 | 08:25 AM
HotRodCrewCab's Avatar
Default Brake Problem
Okay... the truck in my sig has a little brake problem that has developed within the last week or so. Now it doesnt do this every time, but every once in a while. When braking, once the truck gets to about 15mph or less, the abs pump kicks in and wont let the truck stop all the way then when im about to s*@t my pants, the brakes will come back and skid to a stop. My first thoughts would be a sensor, but im not getting an abs light. I have access to a scanner but havent gotten it on yet to pull codes. Just wonder if there is maybe a simple\stupid problem or if anyone else has had this happen?
Old Dec 28, 2009 | 09:14 AM
ArizonaRedneck's Avatar
what kind of shape is your vacuum pump in and what about your vacuum hoses are they in good shape mine is doing the same thing at low rpms i am thinking my pump is in need of attention it has almost 300 hundred thousand though
Old Dec 28, 2009 | 09:24 AM
There is only 91k on my truck, so I would venture to say the vac pump is ok. And am I correct in saying my brakes are run off the power steering pump, not vacuum?
Old Dec 28, 2009 | 09:32 AM
blkjack's Avatar
You are correct they use hydroboost not vacuum assit brakes. Im thinking that it is in the hydro boost not actually the ABS side. Hows the p/s fluid condition and level?
Old Dec 28, 2009 | 12:30 PM
dirt diggler's Avatar
my truck did the same thing. One top of the rear end there is a plug in for the speed sensor i un pluged it and it stops fine but the abs an break light stays on . So you could unplug this and see if its your rear speed sensor i would say thats your prob
Old Dec 28, 2009 | 01:21 PM
Thats kinda along the lines of what I was thinking. Im gonna go check the p/s pump fluid first though, cause thats an easy quick step. But Im banking on that sensor being the problem.
Old Dec 30, 2009 | 05:39 PM
It was the speed sensor.... good call
burndiesel
10
Feb 7, 2023 01:15 AM
Hogridenfool
Nov 20, 2017 04:37 PM
Turbo67
Jul 25, 2015 02:26 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
njnick
Nov 17, 2014 01:13 PM
