throttle postion problems
Old Dec 27, 2009 | 07:38 PM
02 cummins's Avatar
Angry throttle postion problems
Alright so here goes. I go down the road say at any steady speed. Once in a while I get total dead pedal just for a couple of seconds. then on the off then on again. check engine light comes on. Reads fault code for tps. Tps is changed and same problem. Most of the time now when you are at a steady speed the rpms jump all over the place meaning down and up but never higher then what I have the accelerator pressed. I have had it to a shop they think it is an intermittent wiring issue. I have changed the tps and the alternator tps has also been adjusted checked all battery connections and cleaned them.some one please try and help me.
Old Dec 27, 2009 | 07:49 PM
12vcummins96's Avatar
u need to reset the apps sensor
Old Dec 27, 2009 | 07:50 PM
RAW's Avatar
RAW
How about the connections between the APPS and the ECM? Kind of sounds like there is a connection that is being temporarily interrupted.
I have also heard that relocating the ground wire to/from the APPS can remedy throttle position issues, and TQ issues as well.
Old Dec 27, 2009 | 07:52 PM
turbo20psi's Avatar
Clear the codes after you reset the APPS.
02 cummins's Avatar
sensor has been reset quite a few times, it will also go like 2 or 3 hours of plowing running just fine
Old Dec 28, 2009 | 11:03 AM
jkidd's Avatar
sure you got a good tps?
Blair@BD
BD-Power
Sep 10, 2015 12:29 PM
Jake202
Jun 21, 2015 09:42 PM
94deisel
May 11, 2015 10:17 AM
Ol Goat
Jan 22, 2015 02:16 AM
1stgenswap
Nov 3, 2014 09:45 PM
