1999 dodge ram 3500 24 valve abs and brake light on???
Old Dec 27, 2009 | 04:55 PM
jrhbull74's Avatar
Default 1999 dodge ram 3500 24 valve abs and brake light on???
Any info on this problem im looking to buy this truck 1999 dodge ram 3500 24 valve dually 136,000 miles with these lights on.$10,900 is this a decent price?? Thanks
Old Dec 27, 2009 | 04:57 PM
12vcummins96's Avatar
does the speedo work
Old Dec 29, 2009 | 12:58 PM
crazycooter's Avatar
I have the same lights on, and I have no concerns with operations. All of the homework I have been doing, (not having an OBDIII scanner) It could be related to an air bubble in your power steering system as that provides the boost for your power brakes. I am going to bleed mine by the book here one of these days and see if that doesn't get R' done...
Old Dec 29, 2009 | 05:36 PM
2500superram's Avatar
wire's from the front wheel abs sensor's on my truck wore on the brake hose's.both side's(pass. and driver) were cut all the way through both conductor's.i ended up splicing them with some weather tight crimp connector's.
Gitana
Nov 25, 2014 06:25 PM
