diesel smell in cab
Old Dec 26, 2009 | 11:50 AM
KLOVE's Avatar
Default diesel smell in cab
i have a diesel smell in my cab when i let my truck sit there an idle with the defrost on. Anyone know why?
Old Jan 5, 2010 | 10:57 AM
DUMDOWN's Avatar
I have the same problem. Will be watching this thread.
Sorry no answer
Old Jan 5, 2010 | 11:01 AM
BC06PSD's Avatar
Hole in up pipe possibly. Check under your hood for signs of soot. If your getting diesel fumes in the cab that is the most likely cause.
Old Jan 5, 2010 | 02:14 PM
msikes's Avatar
I had the same. I just figured out it is my fuel filter lid leaking in the engine compartment.
Old Jan 5, 2010 | 10:53 PM
04redstroker's Avatar
Does it smell like diesel exhaust or diesel fuel? The regulator on the filter bowl was leaking on my truck awhile back. Would only smell diesel sometimes until it got really bad, it wont leave a puddle either. It wont leak if the trucks not running. Took me about 15min to replace the oring and problem solved. You can find it on the front of the fuel filter bowl on top of the motor. It has 4 small screws holding the cover on and a fuel line on it.
Old Jan 21, 2010 | 09:10 AM
grabber1's Avatar
I had this same prob too but mine was a torn turbo hose. Replaced it and prob solved.
Old Jan 26, 2010 | 07:07 AM
tworks's Avatar
the stainless steel y pipe to the turbo have a tendency to crack behind the heat shield like BC said , check for soot on the fire wall and along the manifold mounting studs
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
May 6, 2015 03:20 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
