front end alignment?
Old Dec 26, 2009 | 12:51 AM
dan33klein's Avatar
Default front end alignment?
hey guys, i have a set of pro comp X terrains on my rig. i havent been paying attention to tread wear untill lately. the tires were ok when i bought the truck and i barly put 5 thousand miles on it in. the two years i had it(i just got my license a few monthes ago, been modding this thing since i was 14). but anyways the back tires are good with alot of tread and the front tires are almost bald!!. i know my ball joints are shot, me and a guy up the street are going to do mine when he does his on his 06commonrail. that will help some. but how can the front end be that screwed up to screw that alignment. track bar? the guy said he replaced both tierod ends. and i replaced the one at the pitman arm. and i dont remember him saying he got it aligned? could that be a problem? should i look into a track bar? thanks
Old Dec 26, 2009 | 07:53 AM
STUMPMAN's Avatar
Front ends are constant on these trucks, you will see. Yes, check your track bar, make certain everything is tight, then have it aligned. You will get good at replacing front end parts quickly
Old Dec 26, 2009 | 09:20 AM
dan33klein's Avatar
haah, thanks for the news . im gunna check all that out, maby get a profab track bar, new ball joints, new tires, and a good alignment
Old Dec 26, 2009 | 01:12 PM
Hammer's Avatar
ANYTIME you change a tie rod ends you need to have the alignment redone.Ball joints being shot will also kill a set of tires quickly and with Pro-Comps being so soft they will dissappear quickly.Also of note all Pro-Comp tires should be rotated every 6k or they will begin to wear strange or show signs of cupping.Local Pro-Comp rep looked at mine a couple weeks ago while I was at the tire shop geting them rebalanced and rotated and I had mentioned to him about the strange wear patterns.he then asked me the milage since the last balance and rotation and when I told him 12k(which is about what I normally do and have had no isses with) he told me that Pro-Comp "should" be rotated every 6k and it was a good idea to rebalance them also.The shop that does mine has a load force balancer and uses Nitrogen and I have always gotten good wear out of my tires at 12k intervals but am going to switch to every 6k and see what happens.I have 35k on my Extreme M/T's and am hoping to get them to at least 50k before I change them.......Andy
Old Dec 26, 2009 | 02:16 PM
oglejust's Avatar
u need to align after tie rods and pitman/ider arms.. at least get the toe set.. and hammers ideas not too bad, we have a road force balancer at the shop... good stuff
Old Dec 27, 2009 | 02:44 AM
dan33klein's Avatar
yeah i definatly need to get all that done. the tires are already shot tho so theirs no saving them. may as well save up for all the work to be done and new tires.
shingi
Off Roading
Sep 30, 2015 11:17 AM
tbirdz24v
Aug 22, 2015 06:41 AM
Slim Whitey
Wanted To Buy (WTB) - Used
Mar 3, 2015 06:15 PM
2FordStrokers
Jan 11, 2015 09:40 PM
Cumminsman911
9
Nov 1, 2014 04:07 PM
