Rpm problems
Old Dec 25, 2009 | 01:45 PM
6.5L's Avatar
Default Rpm problems
My 96 has been giving me issues I cannot keep it at a constant speed when I try to hold it steady the Roma bounce up an down if I put the cruise on it will bounce up and down and rpms won't stay steady..
Old Dec 25, 2009 | 01:50 PM
wildbill's Avatar
Did you recently fill up?? Does it seem to be lagging on power??
Old Dec 25, 2009 | 08:10 PM
6.5L's Avatar
no it doesn't matter how much fuel is in it..and yes its lagging on power and puking out a bunch of smoke i can't drive it without fogging up the road behind me i figured out the reason for all the smoke was because i need that mechanic wastegate boost controller to bypass my vaccum system but haven't got to fix it yet..but then this problem started occuring i have been told it could be my throttle positioning sensor or (tps)
Old Dec 25, 2009 | 08:19 PM
wildbill's Avatar
When did you change the fuel filter last??
Old Dec 25, 2009 | 08:24 PM
6.5L's Avatar
2 months ago...i have also put the FSD on it the upgraded pmd.
Old Dec 25, 2009 | 08:27 PM
wildbill's Avatar
Did you fill up recently?? May have gotten a batch of bad fuel (it happens) and it clogged the filter enough.
Old Dec 25, 2009 | 08:31 PM
6.5L's Avatar
umm well it could be..but i will put more fuel in it tomorrow...but it has been puking out a bunch of smoke for the last month or so..
Old Dec 25, 2009 | 08:34 PM
wildbill's Avatar
Top of the fuel tank, then change out the fuel filter. Be sure to dump the fuel out from the old filter into a container. This way you can see if there isn't a fatal amount of water and dirt being drawn from the tank.
Old Dec 25, 2009 | 09:00 PM
6.5L's Avatar
Alright but do you think these 2 problems are connected
Old Dec 28, 2009 | 09:32 PM
Woody35's Avatar
not being able to hold a constant rpm is a sign your ip is going out but you have other problems so it could be anything
