bad MPG
Old Dec 24, 2009 | 10:46 PM
skyjacked84's Avatar
Default bad MPG
i did the math an im only gettin like 11 MPG. i dont hammer just drive it normal. would this be the fuel filter? i use power service a few times. ive heard the diesel out here in hawaii has lots of water in it.
Old Dec 24, 2009 | 10:49 PM
wildbill's Avatar
The injectors and the twins kit are probably not helping much. Takes fuel to push that much air. Drain the filter housing into a clean, clear container and see what's going on for contamination.
Old Dec 24, 2009 | 10:50 PM
12valvetater's Avatar
Poor fuel quality, dirty air filter, low fuel press, timing, cold, short trips, using 4wd, wide tires. Just a few reasons for bad fuel mileage.
Old Dec 24, 2009 | 10:53 PM
STUMPMAN's Avatar
Huh, you want to mod your truck and get 20mpg?
Old Dec 24, 2009 | 10:54 PM
i think one of my o rings is also bad, i can hear what sounds like a ticking sound.
11 just seems really low.
Last edited by skyjacked84; Dec 24, 2009 at 10:54 PM. Reason: Automerged Doublepost
Old Dec 25, 2009 | 12:01 AM
wildbill's Avatar
Lets see, airaid stage I, aero turbine muffler, banks intake horn, edge juice w/ attitude and I was getting 24 hand calculated.
Old Dec 25, 2009 | 01:32 PM
mylilpwny's Avatar
i know that diesel in Haiku and Paia tend to have a decent amount of water in them ... and in Hana i wouldnt even buy fuel ... ... i know that the guys at Ulupalakua have had water in the fuel issues in the ranch truck ... and i have had it a few times in my truck over at the house so it could be contributing but i dont think its enough to cause it to be that low ... but im sure the mods dont help much ... i know my truck back home only gets around 15 ... i have the bug and bus for fuel econ
Old Dec 25, 2009 | 03:53 PM
Hammer's Avatar
I snicker myself when I see posts like this one also.
BOMB your truck,then want fuel milage...OK,What Did I miss?.
While most would say that BOMBing their truck helped their fuel milage I would have to say that would be true AFTER the novelty wore off.When one first adds power to their respective rides fuel milage ends up going up in a cloud of smoke as the owner gets aquainted with their additions.Most will tell you that BOMBing for milage and power are two completely different tunes and two completely different ways to go about them.
Do the simple stuff first...
-Normal Maintence,adjust the valves and check the timing.
-Look your fuel system over for any signs of leaks or air getting into the system.
-Check the Charge Air System for boost leaks.
Then if you find all of the above is inline and ready you may want to slde the plate back and tighten the AFC down some to lean out the bottom end.
OR....
Place a stop under the throttle pedal and do not allow yourself to show off to anyone....Andy
P.S.-I'd bet the fuel over there is not the greatest and may be an issue also.
bbilt
5.9L Rotary Performance
May 29, 2015 07:05 PM
Smokin Joe
Mar 29, 2015 12:18 PM
Feb 5, 2015 12:10 AM
Jan 14, 2015 03:40 PM
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
Nov 29, 2014 12:40 AM
