what if compression test shows lost?
Old Dec 24, 2009 | 11:50 AM
bowtech's Avatar
Default what if compression test shows lost?
i haven't had one done but if it isnt up to par what it cost to fix? have to rebuild every thing? i have a 94 with like 194 thousand i think. i was going to have it checked out soon see what it looks like
Old Dec 24, 2009 | 11:53 AM
12vcummins96's Avatar
a rebuild kit is 700 bucks plus 1500 in labor
Old Dec 24, 2009 | 04:21 PM
bowtech's Avatar
how much extra would it be to bore it out a little? is there a certain size next step up from a stock?
Old Dec 24, 2009 | 04:57 PM
cummins95's Avatar
194,000 is just barely broke in haha. i got 276,000 on mine n she runs like a top. im bettin ur fine for a long time. unless its had crappy maintenance or been really beaten on. theres plenty of these trucks with a million or more on em. just goes to show, 6 is greater than 8...
Old Dec 24, 2009 | 07:29 PM
bowtech's Avatar
yeah im sure its fine i just need to advance my timing and get a set of 215 injectors
Old Dec 24, 2009 | 07:56 PM
wildbill's Avatar
If compression shows weak, you can re-ring it, but then you stand a chance of stressing the rod bearing from the increased compression, and will ultimately lead to a thrown rod.
Old Dec 24, 2009 | 08:51 PM
12valvetater's Avatar
Rering it, roll new bearings in and reseal it. problem solved.
Old Dec 25, 2009 | 08:48 AM
bowtech's Avatar
how much it cost to re ring bearings and reseal?
Old Dec 25, 2009 | 10:27 AM
400ish
Old Dec 25, 2009 | 10:42 AM
BigDiesel359's Avatar
What makes you think it won't be up to par?
