tryin to make power
Old Aug 4, 2007 | 10:49 AM
younggun2's Avatar
Default tryin to make power
i inherited a 98 dodge 3500 dually and i wanted to run bully dog triple dog on it...but a friend of mine says its not a good idea to run heavy duty programmers on stock injectors...do i need to upgrade my injectors?...ne suggestions for more power would be nice
Old Aug 4, 2007 | 11:10 AM
First of all - WELCOME to the site. Lots of great info and guys here.
Second, is this a 12Valve or a 24Valve? In 98 there were two different engines.
Third, SSSSLLLLOOOWWW down a bit....do you understand the importance of guages? You dont mention guages or even the use of the outlook monitor. If you dont know much about diesels - heres the short and sweet on a 24V - using a programmer changes the fuel map and adds more fuel. Therefore, its necessary to monitor the exhaust gas temperatures with a pyrometer. This is necessary because the added fuel creates much more heat and if you dont have a pyrometer, you run the risk of melting pistons. You will also want a boost guage to monitor turbo performance and a fuel pressure guage to monitor the health of your lift pump. This is the absolute minumum that you will need.
Also, if you have a 24V you should also be looking at upgrading the lift pump.
Old Aug 4, 2007 | 01:50 PM
younggun2's Avatar
its the 24 valve and sorry i left out i do want the outlook monitor with it...im going to get a BHAF and stacks too
Old Aug 4, 2007 | 02:11 PM
Uh, ok...so you have an idea about what is involved.
Im not sure how aggreesive the bullydog box is, but I think you will be just fine with your stock injectors (for now anyway). I think you are much better off getting a fuel system upgrade and mechanical fuel pressure guage.
Old Aug 4, 2007 | 02:20 PM
younggun2's Avatar
any suggestions for brands or anything?
Old Aug 4, 2007 | 02:22 PM
brands of what?
Old Aug 4, 2007 | 02:26 PM
DBogo's Avatar
gauges, autometer, isspro, diprocal there all good
bhaf, you can get them amost anywhere if you need a list of part numbers let me know
stacks, talk to grand rock
last but not least theres better programmers out there then the bully dog, like a smarty
Old Aug 4, 2007 | 02:31 PM
DB Admin's Avatar
Banned
Best to Prepare for the bombs , Is it an automatic?
And Get a Fuel Pressure Gauge ASAP Cause our Stock Fuel Pumps Suck and it will die and take your Injection Pump with it ,
Once you have a good Platform the Skys the limit , But if you spend all your Money on Bombs then Something happens / Breaks because of last of preparation , Then you have a kick *** truck thats a lawn ordiment , Mines been like that a few times its not good
DM
Old Aug 4, 2007 | 02:49 PM
Youll want a FP guage for sure. Seriously, it can save you a thousand+ bucks. I recommend Isspro (they match the stock guages the best), or DiPricol.
Get a 0-30 psi guage like this one:
http://www.dieselmanor.com/isspro/r5..._fuelpress.asp - If you go with Isspro make sure you get the EV (enhanced visibility) series guages.
or this one:
http://www.dieselmanor.com/dipricol/c307425opx_fuel.asp
I also like the Stewart Warner Performance line:
http://www.sw-performance.com/index....tails&p=114382
Old Aug 4, 2007 | 03:29 PM
cashwheel's Avatar
unless I'm mistaken the only bully dog for the 24v is the torque dog, the triple is only for the gen 3's
