lost power
Old Dec 23, 2009 | 06:35 PM
H Bomb's Avatar
Default lost power
put my 366 spring in yesterday and im only running 28 pounds of boost now it was 32 pounds i turned fuel screw all the way, in any ideas
Old Dec 23, 2009 | 07:25 PM
Alwaysworking's Avatar
indexed the throttle wrong?
Old Dec 23, 2009 | 07:46 PM
RSWORDS's Avatar
Thats would be my guess, how is the idle?
Old Dec 23, 2009 | 08:01 PM
H Bomb's Avatar
i didnt look at notches when i tore it down, so when i put it back together it tried run away four times then i hit the right one, it idles good, i just took the high idle screw off yesterday so i figured that would give it a lil more but i dont know, i really miss those four pounds though,
Old Dec 23, 2009 | 09:12 PM
stillcummin's Avatar
Check the spring and corresponding levers from the fuel pin.Did you remove the fuel screw when you put it back together?
Old Dec 23, 2009 | 09:54 PM
jasonfriedlin's Avatar
Mine lost a lil bit of smoke when I did the spring in it but I never looked into it all that much cuz the boost wa about the same and the truck would run better than it ever has.
Old Dec 25, 2009 | 11:58 PM
seandonato73's Avatar
yea i would have to go with the throttle index is off, i had more boost after i put my 3200 gov spring in.....
Old Nov 22, 2010 | 12:20 AM
dillybar002's Avatar
u have to adjust full throttle and you should time it too do the starr wheel
Old Nov 22, 2010 | 11:16 AM
Levi Miller's Avatar
mine did the same its prolly the wsrong index mark
Chris Herron
Sep 2, 2015 08:02 PM
4estlee
Oct 7, 2014 07:47 PM
