Multi part Question
Old Dec 23, 2009 | 05:09 PM
crazycooter's Avatar
Default Multi part Question
I jsut did my vp44 and an airdog 100, but still get lousy mileage. I know that the vp was bad and also know that the stock lifter was bad. Is it possible that driving several thousand miles with a bad vp, that I killed my injectors?
Also a guy told me that upgraded injectors even without a chip will give better mileage and more hp. How true is this?
Old Dec 23, 2009 | 09:13 PM
RAW's Avatar
RAW
It is all about how well an injector can atomize the fuel for a better burn. The better the tip on an injector, the better. If the VP was delivering poor pressure, or inconsistent, injector damage could have resulted. Everything wears out in time, no matter how good you are too it.
I have seen comparisons in magazines about how well the "ports" are machined in injector tips, and believe that it makes a difference. Just like the port and polishing was just presented to us, a "port and polished" injector tip should yield similar results.
I believe a premium injector would have better gain than stock, but that's just my opinion.
Old Dec 23, 2009 | 09:57 PM
oudive's Avatar
SO you have a dually, what gear ratio 4:10? That will be a show stopper for higher MPG, is it a 4x4 or 4x2 and that will be another factor.Your injectors could be just dirty. Another set of injectors would not hurt if your planning on building the truck up. I would suggest gauges first.
Old Dec 26, 2009 | 04:01 PM
she was a dually, but now just single. 3:54 gears. I am inclined to think it was maybe the injectors too. i found a set for about $220 shipped that are + 50 hp. I think that is my next project.
Bslamb
Jeep Liberty
Aug 10, 2015 04:28 PM
Mar 4, 2015 08:20 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
jrsavoie
Feb 6, 2015 09:44 PM
countryboy040993
10
Nov 16, 2014 08:21 PM
