coolant
Old Dec 23, 2009 | 05:05 PM
shouldhavebeenadodge's Avatar
Default coolant
I have 6.0 that is useing coolant for a while. I have head studs any other ideas guys. I,m praying its not the heads thats why I did studs. Now sometimes it blows overflow res. If you think its my gasket be nice I might cry if I have to have the cab pulled again.
Old Dec 24, 2009 | 01:17 PM
Diesel Nut's Avatar
Couple of things.
When you had the gaskets done, did they send the heads to a machine shop for pressure test and magniflux?
What studs did they use?
Are you getting any steam out the exhaust? Like maybe the EGR cooler let go?
Is it always pushing coolant or only under heavy load/high boost?
Old Dec 24, 2009 | 05:39 PM
wt_offroad's Avatar
I would suspect egr cooler if it has not been deleted yet.
Old Dec 24, 2009 | 07:30 PM
Sut Pusher's Avatar
Same prob here. I would say EGR.
Old Dec 27, 2009 | 01:52 PM
Egr deleted and under high boost it blows out. But it burns under all conditions. ARP head studs can an egr still rupture if its been delete dang:
Old Dec 27, 2009 | 06:48 PM
Mdub707's Avatar
Mine blew the headgaskets again with ARP's installed, just as easy as the OEM TTY bolts. The dealership did my stud install... that's why it blew again. I'd bet money the heads were never truly flat.
The dealer took my studs out of the truck the last time they did the gaksets and told me they wont do them again. Now I'm waiting for nicer weather to just do it myself, and do it right!
Old Dec 27, 2009 | 07:51 PM
Is there anything else it could be?
can an egr rupture after its been blocked off?
Last edited by shouldhavebeenadodge; Dec 27, 2009 at 07:51 PM. Reason: Automerged Doublepost
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
Rayrock4
Aug 30, 2015 09:45 PM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
