4 wheel drive problems
Old Dec 22, 2009 | 02:30 AM
adub12valve's Avatar
Default 4 wheel drive problems
I have a 1998 2500 and I have been having 4 wheel drive issues. We changed all the lines and everything is new, but the vac doesnt seem to work still. Is there any way to test the vac to see if it is bad, or what should i do? Thank you
Old Dec 22, 2009 | 06:11 AM
12vcummins96's Avatar
get what they call a mity vac it is a hand operated pump you can apply vaccum with itwill also allow you to see if you are getting vaccum to the switch also u can check the switch for proper operation good luuck and hope this helps
Old Dec 22, 2009 | 09:27 AM
STUMPMAN's Avatar
and you can also crawl under the truck and check for vacuum while someone else engages 4wd. be careful. you have do do it while its running.
Old Dec 23, 2009 | 11:27 AM
12.valve.hauler's Avatar
if you find you are getting vaccum and your acuator is working then check the u joints. also try taking the accuator of spray wd40 in both sides of the diaphram and then work it back and forth slowly. they have a tendecy to build condesation and then rust.<-- happened to my dad three times
Old Dec 23, 2009 | 02:47 PM
ok i will try all that, thank you guys very much
cutthroatxxx
Jun 22, 2015 10:16 PM
6.5dieselman
Feb 26, 2015 04:45 PM
MAC4232
Jan 28, 2015 01:46 PM
cummins1998.5
Jan 24, 2015 03:06 PM
2002cabandchassis
Oct 29, 2014 01:59 PM
