Stock boost?
Old Dec 21, 2009 | 06:52 PM
Subliminal's Avatar
Default Stock boost?
Hey guys,
I have a 91.5 with an auto.
I just installed my boost gauge this evening and took it for a test drive.
I'm seeing:
Almost no boost until I get into second gear.
Second gear tops out ~14-15 psi
Third gear gets up to almost 20 psi....but I have to be floored for that.
I turned my pump up about 1/2 turn (left the collar on), did 90 degrees on the star wheel and turned the pin 90 degrees.
Does that sound normal? For some reason I was expecting ~25...I don't know why that is though...just kind of what I thought.
Any feedback on stock boost levels? I'm not sure on the housing, but since it's early intercooled I want to say it's the large housing (dog).
Anyway, thanks!
damon
Old Dec 21, 2009 | 06:58 PM
ArizonaRedneck's Avatar
stock boost should be between 18 and 23 psi of boost somebody will chime in if i am incorrect
Old Dec 21, 2009 | 08:08 PM
RSWORDS's Avatar
Thats correct
Old Dec 21, 2009 | 08:38 PM
Subliminal's Avatar
Sooo....everything on my 'semi-baseline' looks like expected for a stock truck with 155k on the clock and a 3 inch exhaust?
Old Dec 21, 2009 | 08:42 PM
RSWORDS's Avatar
The no boost in 1st is kinda odd... Make sure you dont have any kinks at all in teh boost line, even a spot that was kinked and then bent back is a problem.
Old Dec 21, 2009 | 08:44 PM
Subliminal's Avatar
Roger that...will do. That plastic line is terrible to work with...especially when it's below freezing out.
Old Dec 21, 2009 | 09:02 PM
big bad diesel 416's Avatar
Site Sponsor
Originally Posted by Subliminal
Hey guys,
I'm seeing:
Anyway, thanks!
damon
dont you do an 180 rotation
Old Dec 21, 2009 | 09:30 PM
seandonato73's Avatar
depends on where it was from the factory, i onlyy had to turn mine a little to get it to the deepest setting
Old Dec 22, 2009 | 02:39 AM
peobryant's Avatar
For a factory intercooled truck, that is higher than normal. Even a Non I/C truck stock shouldn't see that much boost.
With the 21cm housing, and the mods you have done, your boost numbers seem fine.
Old Dec 22, 2009 | 07:18 AM
Subliminal's Avatar
Alright, thanks!
Actually, after driving to work this AM I will see 5 or so psi in 1st. Just not very much...of course, it isn't in 1st very long, either.
