6.2 needs more power
Old Dec 20, 2009 | 09:21 PM
wes-cummins's Avatar
Default 6.2 needs more power
hey can any one tell me how to crank up injector pump on 84 gmc with 6.2. just want to get little more out of it. 20-25 horse.
Old Dec 20, 2009 | 09:47 PM
wildbill's Avatar
There's a cover on the side of the injection pump, remove it, then turn the screw about a half a turn or until you achieve the amount of power you want.
Old Dec 25, 2009 | 07:46 PM
thanks. turn it im assuming? is there any thing that can be done to improve air flow on that motor?
in
Last edited by wes-cummins; Dec 25, 2009 at 07:46 PM. Reason: Automerged Doublepost
Old Dec 25, 2009 | 07:58 PM
wildbill's Avatar
There isn't much you can do to improve airflow, other than adding a turbo charger.
Old Dec 28, 2009 | 09:34 PM
Woody35's Avatar
supercharger
Old Jan 26, 2010 | 10:52 PM
87-6.2's Avatar
is it necessary to get an egt gauge if i turn up the ip on a 1987 6.2 c code 1/4 turn?
Old Jan 27, 2010 | 08:07 PM
Woody35's Avatar
it would be reccomended. dont want you to hurt your engine
Old Jan 28, 2010 | 03:09 PM
87-6.2's Avatar
I tried to turn up the pump on my truck last night and I didnt have enough clearance to get the srews out on the side of the pump. Does anybody have any tricks to doing that or is it necessary to remove the intake manifold. (I have an egr intake)
Old Jan 28, 2010 | 10:40 PM
Woody35's Avatar
yup probably going to have to take it off
Old Jan 29, 2010 | 08:13 AM
tony lewis's Avatar
you can take the top off the pump and access the screw also.you will have to take allen bolt out from rear of pump to remove gov assembly out of way just make sure to install as you took it apart
