Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
blue smoke
Old Dec 20, 2009 | 11:12 AM
Dually04's Avatar
Angry blue smoke
Does anybody know if it's normal for my lly duramax to smoke (oil) on the start-up? The truck just started doing it when I hit 103,000 it's not burning or losing oil or pressure.
Thanks, Dually04
Old Dec 20, 2009 | 04:48 PM
2500HeavyDuty's Avatar
what does the smoke smell like?
Old Dec 21, 2009 | 04:27 PM
Dually04's Avatar
Default blue smoke
the smoke smells like oil/ diesel exhaust.
Old Dec 21, 2009 | 04:36 PM
can you do a balance rate test on the truck, it sounds like am injector
Old Dec 24, 2009 | 11:28 PM
K50's Avatar
K50
Yeah that's not good/normal...Something's leaking!
Old Dec 30, 2009 | 12:03 AM
DangerousDuramax's Avatar
Thanks, Dually04
The first thing you need to check is to make sure the PCV system isnt plugged. If it is you will get a white smoke from your exhaust. If the PCV is ok then you most likely have a bad injector thats leaking past the seat until it warms up. Check your oil level and see if there is diesel in it.
Old Jan 16, 2010 | 02:24 AM
dirty_d_max's Avatar
sounds like you"ve got a bad barrel and it's over fueling when you shut it down and it loses rail psi.
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
tim12valve
Jun 16, 2015 09:59 AM
gagemotors
Jun 9, 2015 04:24 AM
honda89
Dec 27, 2014 06:19 PM
lil red
Oct 10, 2014 09:03 AM
