Re-Torquing STOCK Head Bolts Questions
had an experience tonight, i want to ask some questions, get some answers then i will go through what went down.
1. Is it "OK" to re-torque factory installed head bolts?
2. If it is "OK" to does mileage have any affect on them?
3. What is the acceptable ft/lb of Tq that you can torque the bolts to?
only time i have retorqued a head bolt is during installation of head. always checked torque twice just to check myself than ran engine to operating temp check for leaks and any extra rattles and then shut off and let cool and then check torque again but i dont think checking them is a bad idea especially if your comfortable doing it and stretching your head bolts will only happen if you take them to a higher torque value then they were at or from the factory http://www.dieselpowermag.com/tech/d..._to/index.html see if this will help with your questions
well here is what happened,
all the
big guys
in the diesel scene that live around me (not calling names but one has a pro-stock truck and one has a green "street" truck) all say to re-torque the head bolts up to 130 ft/lbs. we installed a set of 370 marines, and bumped the timing to 16*, decided since the injection lines were off that we would re-torque the head.
for the record this is on a 96 ram 2500 with a little over 420K miles. anyway, in the middle of re-torquing the head one of the bolts broke off in the block. we torqued them to 130 ft/lbs. we broke each bolt lose one at a time before re-torquing them.
this is an announcement, by me, take it as you will, if you are going to take head BOLTS above stock specs, BUY A NEW SET and install them one at a time, and then torque them to a higher setting.
I WILL NEVER RECOMMEND RE-TORQUING OLD STRETCHED HEAD BOLTS DUE TO THE POSSIBILITY OF THEM BREAKING.
pictures will be posted later of the broken bolt. luckily we were able to remove the offending piece in the block without having to remove the head and replaced it with a lower mileage head bolt out of my truck since i am upgrading to studs.
all the
big guys
in the diesel scene that live around me (not calling names but one has a pro-stock truck and one has a green "street" truck) all say to re-torque the head bolts up to 130 ft/lbs. we installed a set of 370 marines, and bumped the timing to 16*, decided since the injection lines were off that we would re-torque the head. for the record this is on a 96 ram 2500 with a little over 420K miles. anyway, in the middle of re-torquing the head one of the bolts broke off in the block. we torqued them to 130 ft/lbs. we broke each bolt lose one at a time before re-torquing them.
