9mm to 7mm conversion
Old Dec 19, 2009 | 06:29 PM
Smokem's Avatar
Default 9mm to 7mm conversion
I recently received a set of stock non I/C injectors from a member, the goal is to convert them to be used with an I/C head that was exchanged. I will post some more pictures and information later, so far this is the visible change, stock on left machined on right.
Old Dec 19, 2009 | 07:47 PM
Budgreen's Avatar
just turned down part of the nozzle? wouldn't it be a wash in machine time vs. buying new nozzles?
Old Dec 19, 2009 | 08:37 PM
big bad diesel 416's Avatar
Site Sponsor
SWEET MAN i need them ASAP that pop pop noise is driving me nuts and the power sucks take lots of pics and notes iam curious on this
Old Dec 20, 2009 | 12:21 PM
Smokem's Avatar
Time is not my concern, even if I paid to have the nozzles turned down, it would be much cheaper, but since I am doing the machine work, that is not an issue.
Old Dec 20, 2009 | 12:44 PM
Benjamin's Avatar
Bombardier
so you can remove that much material and there will be no "structural" issues? just wandring...
Old Dec 20, 2009 | 01:15 PM
Smokem's Avatar
Yes, the common 6-hole Sac nozzle used in the 24v application is a Mack nozzle turned down in the same fashion.
Old Dec 20, 2009 | 02:34 PM
Benjamin's Avatar
Bombardier
that is cool that they are that thick. i guess you are only removing 1mm of material off them so it isn't like a bunch.
Old Dec 20, 2009 | 08:29 PM
Smokem's Avatar
A few pictures of the process.
And the finished product.
The set fired really well for being 20yrs old, I added 0.010" lift and set the opening pressure to 245BAR, they originally ranged between 200-225BAR.
Old Dec 21, 2009 | 01:19 AM
Site Sponsor
oh god i just peed a little when i saw that
iam so excided
weston the 245 bar thing i trust you 100% but i have been told that will ware the pump out realy fast because it has to strugle to get them open?:
what did you paint them with
Last edited by big bad diesel 416; Dec 21, 2009 at 01:19 AM. Reason: Automerged Doublepost
Old Dec 21, 2009 | 11:24 AM
Smokem's Avatar
Stock opening pressure is 245BAR, I removed the paint.
