Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
LBZ Mouthpiece
Old Dec 19, 2009 | 03:17 PM
pac_master_7@hotmail.com's Avatar
Default LBZ Mouthpiece
Ok so i know from reading several threads about this that the LLY Mouthpiece sucks some major co** So where exactly can i get one and what will it run me on cost. Also which is better, the LBZ Mouthpiece or the AFE Bladerunner?
Old Dec 19, 2009 | 05:57 PM
2500HeavyDuty's Avatar
probably from a junk yard, the lbz mouthpiece on a lly isnt a direct swap but it can easily be fitted with the right pieces of intake tubing.
heres a good site to find all the pieces you need to swap a lbz piece onto it. Intake Hoses, IntakeTubing, and Intake Clamps
the afe plade runner claims to alot more efficient than the lbz mouthpiece swap, jlawles has one on his truck iirc
Old Dec 19, 2009 | 06:17 PM
Well i'm not to worried about the intake tubing cause i have a cold air intake which when i bought it i didn't know about the different duramax motors so it's actually for a LBZ and i jsut kinda made it work on my truck. So what would you recommend? LBZ or AFE.
Old Dec 19, 2009 | 06:25 PM
the afe one is over 300 dollars MSRP
the lbz can be found for alot cheaper, or a kodiak lly one works too but ir depends on what you want to spend.
Old Dec 19, 2009 | 06:40 PM
Definitely don't wanna spend that kinda money. The junk yard thing kinda crossed my mind today as i passed one but then i was thinkin what are the chances that a truck that new is still gonna be in a junk yard. I guess it's worth trying. I know that they only cost like 80 or 90 dollars new off the gm parts website.
Old Dec 19, 2009 | 06:48 PM
jbrown1132's Avatar
gmpartsdirect is usually the best source.
Old Dec 19, 2009 | 07:03 PM
Yeah that's what site i was lookin on. I still think i should take a look at a couple of the local junk yards first though. Surely there's one layin around somewhere that's in half way decent shape. Other than the intake not fitting is it a direct bolt on part?
Old Dec 19, 2009 | 08:39 PM
jlawles2's Avatar
The blade runner is a direct bolt on, no cutting or reducers required. I did the aFe as I did not want to take the time to cut the intake tubing. The hardest part was getting the 2 plugs from the hardware store to do the pcv reroute and resonator block.
Old Dec 19, 2009 | 09:14 PM
Yeah i don't have to worry about the intake tubing. I bought a Cold air intake a while back and it was actually made for a lbz and i somehow managed to make it fit.
Old Dec 21, 2009 | 10:08 AM
travelswithcharly's Avatar
No, It is not a swap out. There is some work involved to machine off interferences and you have to find a coupling that is the right size, etc. There is a kit you can get that is a designed fit. Induction Overhaul Kit that has everything you need, in the right materials. It is more expensive also but everyone loves it for how much better the truck runs.
rowekmr
Chevy/GMC Duramax 06-07 LBZ
Apr 30, 2015 07:05 PM
RLLBZ
Chevy/GMC Duramax 01-04 LB7
Jan 27, 2015 03:05 PM
duramaxtuner
06-07 LBZ Performance
Dec 10, 2014 02:00 PM
DPRacing805
For Sale
Nov 15, 2014 12:47 AM
patrickbruno91
Nov 7, 2014 11:54 AM
