AFC ADJUSTMENT
hey does anyone know about an adjustment on the front of the afc housing? if you lossen up the bolt the shaft can be rotated a little bit. i noticed by rotating it, it slightly turned the afc arm which has a little bit of a beval?
yes I have and I did not like it ( way to smokey) ... your better off grinding the end of the barrel.
Stock afc foot
modded barrel you want to take about .090 off the end with a grinder ... I got a little grinder happy with this one.
THANKS ALOT MAN. WILL THIS ALLOW THE GOVERNOR ARM TO TRAVEL ANY FURTHER IF IM RUNNING WITH OUT A PLATE?
