need more power at higher speed???
Old Dec 19, 2009 | 03:48 AM
powermad's Avatar
Default need more power at higher speed???
so my truck runs strong up till around 60 then doesnt give much after that. i can go wot and it just doesnt jump like i feel it sould. i am used to my old 2001 and it would go from 65 to 105 in a blink of an eye. so my question is what else do i need to get more out of the top end? will pushing the plate full forward and getting a set of 191 dv's help this?
Old Dec 19, 2009 | 04:08 AM
12vcummins96's Avatar
get a bigger plate and some injectors do you have a govenor spring kit
dvs will help a little but injector will help more
sorry didnt see the gsk in the sig till now
Last edited by 12vcummins96; Dec 19, 2009 at 04:08 AM. Reason: Automerged Doublepost
Old Dec 19, 2009 | 06:15 AM
powermad's Avatar
yea i have 3000gsk if i push the plate full forward will that help much? i also dont want a smokey mess either, im thinking about some 5x.012's. what pump mod causes most the smoke? i want to be as smokless as possible. ive know that the smoke is controlled 99% by the driver but we all know that these trucks smoke. oh and what the difference between 191dv's and other size dvs and what do they do? sorry for all the questions.
Old Dec 19, 2009 | 06:33 AM
DB Admin's Avatar
Banned
do you have 370 injectors?
Old Dec 19, 2009 | 07:52 AM
PhilipR's Avatar
Slide the plate and tune the AFC....that will control the smoke down low and the the plate FF will give the rack more travel for your upper R's fueling you need.
Old Dec 19, 2009 | 08:21 AM
powermad's Avatar
thats exactly what i was looking for! im going to put a set of 215 pump injectors in and do some grinding on the plate. so how do i tune the afc? and does anything need to be done with the star wheel?
Old Dec 19, 2009 | 08:48 AM
STUMPMAN's Avatar
I know there is a nice article about tuning the afc somewhere, I looked but can't find it. I know Duster can find it, he's good at that stuff. I did injectors first, made a difference, added in DV's later and it made a noticeable difference. My truck can be smokey as you want it, or you can drive it normally and not see any smoke at all. its up to you. I think its hard to do all these mods and not have any smoke whether you want it or not.
Old Dec 19, 2009 | 08:52 AM
PhilipR's Avatar
Not if the AFC is tuned in right. I am going to do an AFC tuning thread between Christmas and New Years with pics and all.....if you cant wait do a search and you'll get TONS of hits.
Old Dec 19, 2009 | 10:49 AM
oglejust's Avatar
if u put dv's in ull def have smoke
Old Dec 19, 2009 | 10:55 AM
94 12valve's Avatar
timing bump
