hard start in morining only when parked at an incline is my IP BAD?
Old Dec 18, 2009 | 07:47 PM
asabadin's Avatar
Default hard start in morining only when parked at an incline is my IP BAD?
Ok 2 out of 7 mornings this week My truck has taken like 15 seconds to start. My truck is parked on an incline going up my driveway. Once it get's started, I can turn it off and it will start as normal in one bump. No other hard starts during the day at all or surging. Is ny IP bad? I hope not. Or is my lift pump bad? It never get's colder than like 30 degrees in my area. Any info would be great guys. thanks.
Old Dec 18, 2009 | 08:21 PM
powermad's Avatar
do you smell fuel anywhere? or have any visible fuel leaks? try parking it with the nose face down and see if it starts faster. it could be a cracked fuel line, return line, leaking crossover tube... basically anything having to do with your fuel system should be checked. my old 2001 cummins had a etch in the crossover tube and it caused the same problem you have now.
Old Dec 18, 2009 | 08:25 PM
ArizonaRedneck's Avatar
yep same problem i had fitting loose at fuel pump [main fuel supply line]
Old Dec 19, 2009 | 02:13 AM
asabadin's Avatar
cool ill check it out. thanks guys!
Old Dec 19, 2009 | 06:17 AM
powermad's Avatar
another thing to check is if you have good voltage while cranking the engine over.
94turbostroker
Feb 26, 2016 07:51 PM
Dcbb93
Nov 30, 2015 10:18 AM
Blanton
Apr 15, 2015 06:29 PM
dfish001
Mar 30, 2015 03:07 PM
trab123
Feb 9, 2015 09:44 AM
