why???
Old Dec 17, 2009 | 04:20 PM
jake 94's Avatar
Default why???
got a question my truck has all the stuff in my sig. but i have a bad clutch and the timing is still at stock but the thing im tryin to figure out is why it doesnt smoke black at all even when i put it to the floor i get nothing can someone help me get some smoke its boring driving around without it
Old Dec 17, 2009 | 05:19 PM
monster12valve's Avatar
check the fuel pressure yet?
fuel filter been changed? fuel lines leaking? how bad is the clutch slipping?
Last edited by monster12valve; Dec 17, 2009 at 05:19 PM. Reason: Automerged Doublepost
Old Dec 17, 2009 | 05:44 PM
lodal cummins's Avatar
move your fuel plate full forward as well as the afc.crank the starwheel forward. but only if you have gauges. that will get her to smoke!!!!! p.s. this will destroy your clutch!!!!
Old Dec 17, 2009 | 07:02 PM
with a 10plate in stock location he should still be seeing smoke.
Old Dec 17, 2009 | 07:22 PM
Lil Red Express's Avatar
AFC is to tight, needs to loosened all the way forward.
Old Dec 17, 2009 | 11:44 PM
jake 94's Avatar
i had the plate all the way forward and the AFC and i still didnt have any smoke
Old Dec 18, 2009 | 02:05 AM
Send your turbo to me, I will send you an HX-35 and youll have lots of smoke.
Old Dec 18, 2009 | 03:32 AM
97cummins's Avatar
Old Dec 18, 2009 | 06:57 AM
STUMPMAN's Avatar
Unburned fuel is smoke, so concentrate on that. Dirty injectors, dirty filters,lift pump weak. Put a fuel gauge to it, that thing should be rollin some coal.
Old Dec 18, 2009 | 07:31 AM
PhilipR's Avatar
I don't see the problem.....you smoked your clutch and it seems the truck is making power. You have an aftermarket turbo that will move more air and some bigger junk injectors....why the fascination with smoke? I guess you like wasting fuel. if the FP is good, the filter is clean, the sediment bolw screen is clean and your timing is right then you have a well tuned truck and should be happy.
