Injector Pump Help
Old Dec 17, 2009 | 01:27 PM
dodgeflatbed's Avatar
Default Injector Pump Help
My buddy just bought a n '82, and i was wondering if there was any ay to turn up the injector pump like on the first gen dodges. i looked at it, but didnt want to mess with anything. thanks for the help
Old Dec 17, 2009 | 03:26 PM
Woody35's Avatar
There's a 5/32" allen under the fuel stop sol. & cover, but is very risky to do. This engine can "runaway" if you're not careful. You have to remove the little linkage pieces inside the bowl. I think there's a spring, a small tin-like lever for the shutoff assembly, and the throttle/fuel control sliding plate. There's also a side access cover to get to the adjustment without having to disable the fuel shutoff and remove accelerator sliding pieces and springs. After you take off either cover (and/or the pieces inside) you'll notice a small hole, that's where the 5/32" allen goes. Sometimes it needs to be lined up by rotating the engine. Disable the glowplugs before doing this part! If you slowly rotate it by the alt. you'll see it come into sight. Now turn the allen about 1/4 turn clockwise, less on non-turbo and reassemble it all
Old Feb 11, 2010 | 08:58 PM
danielfoxracing's Avatar
1/4 turn thats it trust me
