95 6.5 gmc what to look for
Old Dec 16, 2009 | 03:00 PM
chili39's Avatar
Default 95 6.5 gmc what to look for
First let me say i am very new to diesel engines but am very mechenicly inclined so bear with me.
Im looking at a 94 gmc 6.5 z71 and i need too now what to look for. the guy says that all it needs is an injector pump. he said when he pours gas into it it starts but then dies and it wont start on its own.
what tests or things should i do when i go look at it to figure out the problem so that i dont buy a juncker?
thanks
Old Dec 16, 2009 | 03:06 PM
wildbill's Avatar
I'd look at a faulty lift pump. Course a bad injection pump causes a no start issue also.
What you can do is loosen the fuel line going into the fuel filter and turn they key on. If you get fuel to it, it's possible the fuel filter is plugged off solid or the injection pump is indeed shot. If you don't get any fuel, got a bad lift pump (if electric).
Now if it's the filter, change it, re-bleed the fuel system, then attempt to start the engine again.
Old Dec 16, 2009 | 03:14 PM
ArizonaRedneck's Avatar
welcome to diesel bombers and looks like bill has got you covered good site and good people
Old Dec 16, 2009 | 09:59 PM
Woody35's Avatar
whats the fuel pressure
Old Dec 17, 2009 | 07:04 PM
jbrown1132's Avatar
Old Dec 17, 2009 | 09:14 PM
dealwithit's Avatar
a couple psi, not much. you should hear it running when you first turn the key on, its down on the inside of the frame rail on the driverside. might also want to try a new PMD as those quit all the time too.
Radioking1777
Jun 9, 2015 04:13 AM
Kujo1999
May 11, 2015 06:15 PM
krackerjacklee
Mar 2, 2015 02:34 PM
greatlakes diesel
Feb 13, 2015 09:55 PM
UC Kid
Oct 23, 2014 05:29 PM
